Ty80 Intermittent Spark
john b
Hi
I've just aquired a TY80 which between now and the 25th December needs to be up and running, and looking immaculate !
First problem is that it won't start. It has an intermittent spark. It will spark a couple of times, miss a couple, spark half a dozen, then miss again etc etc. The spark itself is very strong.
Another question on the choke. Should the choke lever stop both up and down ? The one I have will push down, but springs back up ?
Any help much appreciated - I'm sure this is the first of many posts !
cheers
John
  • 3 months later...
I had the same prob would spark then wouldn't go back the next morn still no spark, took fly wheel off cleaned points with sand paper sprayed everything with WD40 and it sorted it starts first time every time, try it well worth a go, good luck
