dye29 Posted September 20, 2010 Report Share Posted September 20, 2010 (edited) HY I HAVE A MONTESA 4RT 2005 AND JUST BOUGHT IT , IT HAS TROUBLE STARTING SOME TIMES LIKE TAKE APPROX 5 TO 10 MINS AND WHEN KICKING I CAN SMELL PETROL IVE HAD A GOOD LOOK AROUND THE BIKE AND THERES NO LEAKS , I CHANGED SPARK PLUG ,AIRFILTER, BOTH OILS ECT BUT STILL TAKES A WHILE IT RUNS SPOT ON WHEN RUNNING ALSO THE SPARK PLUG KEEPS GOIN A REALLY BLACK SOOTY COLOUR IS THIS NORMAL PLEASE HELP REGARDS STE ALSO ONE OTHER THING I CHANGED THE CLUTCH SEAL KIT AND FULLY BLED THE CLUTCH BUT IT STILL DRAGS ABIT HOW DO I STOP THIS , Edited September 20, 2010 by dye29 Quote Link to comment Share on other sites More sharing options...
dgshannon Posted September 20, 2010 Report Share Posted September 20, 2010 Just in case you were not warned, due to the fuel injection, NEVER touch the throttle while trying to kickstart the bike. 1) Don't kick the bike hard. Just push through the kickstart smooth and even. 2) If it does not start in just a few kicks, reset the injection by opening the throttle WIDE OPEN, and pushing the starter easy through the stroke once. Most of the time that they will not start, and smell as you describe, is due to the engine dying with the fuel injection in the midst of a brain fart mapping wise. Pushing the starter through once, with the throttle open, clears the map and resets everything back to the idle state. After that, will almost always start right up. Quote Link to comment Share on other sites More sharing options...
dye29 Posted September 20, 2010 Author Report Share Posted September 20, 2010 so i open the throttle fully and while doin that push kick start down ,ill try that tommorow i tryed just throttle to reset last time maybe no wonder it didnt hopefully that will sort it thanks, also any idea on clutch regards ste Quote Link to comment Share on other sites More sharing options...
the addict Posted September 20, 2010 Report Share Posted September 20, 2010 Make sure the idle speed is set at about 1800rpm to charge the system, seems high at first but you get used to it. Hold the throttle wide open then close it, then push the kickstart down slowly, should fire next good push Quote Link to comment Share on other sites More sharing options...
jimmyl Posted September 20, 2010 Report Share Posted September 20, 2010 Always stop with kill button - never stall to stop the bike. Make sure tickover is not too low when it does start running. After doing a reset as described above press kill button before trying to re start. I also snap open and close throttle and press kill button prior to starting if it does not start first time. Quote Link to comment Share on other sites More sharing options...
dye29 Posted September 20, 2010 Author Report Share Posted September 20, 2010 thanks everyone for help i think it could be tik over as i slowed it down wen i got it because it sounded really high ,how do i no when its at 18000 rpm regards ste Quote Link to comment Share on other sites More sharing options...
the addict Posted September 20, 2010 Report Share Posted September 20, 2010 how do i no when its at 18000 rpm regards ste When the piston goes flying past your head mate lol, a digital rpm counter is a good buy for a 4rt, quite cheap these days, usually you just wrap a wire around the plug lead to let you know what the tickover is Quote Link to comment Share on other sites More sharing options...
jimmyl Posted September 20, 2010 Report Share Posted September 20, 2010 Was going to say you know it rights when it starts first time and you stop stalling it but think addicts suggestion is better. PS Always let it warm up for a minute or so before opening throttle - don't do a two stroke thing and blip the throttle when cold Quote Link to comment Share on other sites More sharing options...
dye29 Posted September 21, 2010 Author Report Share Posted September 21, 2010 (edited) thanks all for help ill try that now sounds promising , sorry im new to these 4 strokes but is it normal for the engine to have a really quiet rattle, Edited September 21, 2010 by dye29 Quote Link to comment Share on other sites More sharing options...
mark1984 Posted September 21, 2010 Report Share Posted September 21, 2010 dont touch the throttle when starting the 4rt just kick it and it will go. The petrol smell is when you flood the motor with fuel cos you have the throttle wide open. Quote Link to comment Share on other sites More sharing options...
dye29 Posted September 21, 2010 Author Report Share Posted September 21, 2010 anyone no how to use these rpm meters what do you attach it to or point to regards ste Quote Link to comment Share on other sites More sharing options...
dgshannon Posted September 21, 2010 Report Share Posted September 21, 2010 anyone no how to use these rpm meters what do you attach it to or point to regards ste As stated in the post... "usually you just wrap a wire around the plug lead to let you know what the tickover is" Quote Link to comment Share on other sites More sharing options...
dye29 Posted September 21, 2010 Author Report Share Posted September 21, 2010 hy sorry i mean the wireless ones with a laser where do i point them regards ste Quote Link to comment Share on other sites More sharing options...
the addict Posted September 21, 2010 Report Share Posted September 21, 2010 Anywhere near the H/T cable I expect, should pick up the pulse Quote Link to comment Share on other sites More sharing options...
dye29 Posted September 21, 2010 Author Report Share Posted September 21, 2010 hy im not to good with bikes what is hd lead Quote Link to comment Share on other sites More sharing options...
