September 23, 201016 yr Hi All, I have been told that I should use Automatic Transmission Fluid in the clutch side of the engine on my 78 Sherpa 250 - is this correct and if so any recomendations on make, type and quantity. Cheers Marty
September 23, 201016 yr Hi All, I have been told that I should use Automatic Transmission Fluid in the clutch side of the engine on my 78 Sherpa 250 - is this correct and if so any recomendations on make, type and quantity. Cheers Marty ATF by Castrol is fine, use 300cc for Bultaco primary chaincase. Big John
