martymc Posted September 24, 2010 Report Share Posted September 24, 2010 Hi Im thinking about putting a new set of rings in my 02 sy 250 but the rear engine bolt is completely siezed solid, Ive tried a little light heat and a heavy hammer with no joy. Any of you guy's have any tips to get that bugger out? Im not sure if I need the engine out to get the barrel off but i was just going to take it out to make it a little easier. Marty Quote Link to comment Share on other sites More sharing options...
lankydoug Posted September 24, 2010 Report Share Posted September 24, 2010 Use penetrating oil in a spray can and wait a while for it to do it's thing. The best brand I have found is called ( PB Blaster ) it performs miracles. Quote Link to comment Share on other sites More sharing options...
kamiture Posted September 25, 2010 Report Share Posted September 25, 2010 The rear engine bolt made from the aluminum of SY is easily transformed when taking a hit. And, it will make the more extraction difficult. It has clung with the bearing color rust. Therefore, it is also difficult to heat it by there is an enough effect. Moreover, shock gives the color and the engine spacer is damaged. A best method of settlement for you is to use the oil hydraulic press of an enough size. When I had the same problem before, it made like that and it solved it. Anyway, you should obtain a new bolt and the bearing color. The thing of cota315/RTL250R can be used for the bearing color, the oil seal, and the bearing. Quote Link to comment Share on other sites More sharing options...
martymc2010 Posted September 27, 2010 Report Share Posted September 27, 2010 Thanks guys i'll give it a go! Quote Link to comment Share on other sites More sharing options...
