cabby Posted September 27, 2010 Report Share Posted September 27, 2010 Popped a fork seal yesterday, so looking to find out how much oil I put in when replacing the seal ? Also, what's the best weight for the oil. Quote Link to comment Share on other sites More sharing options...
thespikeyone Posted September 27, 2010 Report Share Posted September 27, 2010 Popped a fork seal yesterday, so looking to find out how much oil I put in when replacing the seal ? Also, what's the best weight for the oil. What year of bike is it? For Marzochhi used on 2008 onwards see HERE Cant find the oil quantity for the Paoli forks used on bikes upto and including 2007 but there is a useful set up guide HERE Ring Birketts Tel:01229 716806 he is the guru when it comes to anything scorpa Quote Link to comment Share on other sites More sharing options...
cabby Posted September 27, 2010 Author Report Share Posted September 27, 2010 2007 Quote Link to comment Share on other sites More sharing options...
griffg Posted September 27, 2010 Report Share Posted September 27, 2010 Popped a fork seal yesterday, so looking to find out how much oil I put in when replacing the seal ? Also, what's the best weight for the oil. Paoli forks ...Right 370cc +/-5cc Left 355cc +/-5cc SAE5W oil required. Quote Link to comment Share on other sites More sharing options...
cabby Posted September 28, 2010 Author Report Share Posted September 28, 2010 Paoli forks ...Right 370cc +/-5cc Left 355cc +/-5cc SAE5W oil required. I bow to your knowledge but what's the reason for different in each fork ? Quote Link to comment Share on other sites More sharing options...
griffg Posted September 30, 2010 Report Share Posted September 30, 2010 I bow to your knowledge but what's the reason for different in each fork ? I've no idea. I got the info from an owners manual that I downloaded. The only thing I can suggest is there is different internals as one side does the preload and the other does the damping and rebound. And also it is French made! Quote Link to comment Share on other sites More sharing options...
feetupfun Posted September 30, 2010 Report Share Posted September 30, 2010 I bow to your knowledge but what's the reason for different in each fork ? One leg has a spring, the other doesn't. One leg provides damping in one direction, the other, the other. All will be revealed when you pull them apart! Quote Link to comment Share on other sites More sharing options...
