Oil leaking from crankcase join
mccarro
My 2002 250 txt pro has been leaking oil fr a while from the part of the cases concealed by the swing arm bolt.
I've removed the engine and can see the small leak in the c/case join.
Is it possible to seal this without splitting the cases ?
Because of where it is nothing can sit proud of the surface or it will stop the swing arm bolt sliding through.
Any one had similar problem ?
Thanks
Ello mate.
I had a similar issue on an old rm 250 i had
I did over time split the case and replace the gasket . It stopped the leak , I overhauled the engine so put new case gasket on, But as a get me through i used arldite . Two compounds you mix togther like paste and it dries like metal. might just get a bit in to seal it up.
i can send you some for free as i get kits from work for nowt.
might be worth a try
let me know
regards dave
Ello mate.
let me know
regards dave
Thanks for the reply - I'll give araldite a go or possibly try working a gasket sealer ( blue hermatite) into the joint.
