C15 Exhaust Mod?
mcman56
My C15 project is at the point where I need to mount an "inside the frame" exhaust to get leg clearance. This is a 1960 goose neck type frame. The oil tank has been moved in and slightly forward. See the pictures. (The oil line is not as close as it appears.) There is a section where the pipe sort of steps up and out. It looks like it may be possible to cut and rotate that section so it goes in an down. Has anyone tried that? Or...is it basically easier to build from scratch? Any advice on either option?
