mapping software
clarkie
Unfortunately you need somebody with the original discs or you will have to buy a set from Montesa/Honda.
Software is available to down load to compare and convert software from single to dual maps
http://members.quicknet.nl/sw.zeinstra/4RT/index.htm
Some good info on there as well
I went to the above link and am comparing maps. I assume that "TH" is throttle opening expressed as a percentage, is that correct? What about the colors? do they have a significance? I don't see a legend for them.
If anyone can give a short course in reading these maps it would be greatly appreciated.
thanks jimmyl so from what i gather you can download maps from this web site but you can only load a single map with the single map software and vise versa with the dual maps you need seprate software.Also you can only load single maps unless you convert them to dual but you still need the dual map software to load them to bike and the same if you convert a dual map to single you still need the single map software to load it........if that makes sense :wacko:
Yes - I think
You need the compatible sofware to talk to single ot twin map PTB. The maps need to be the correct format but you can convert formats. I think you need to double check conveted files as errors can some times occur.
Motivata - e mail web site owner- I found him very helpfull
