motosi Posted October 5, 2010 Report Share Posted October 5, 2010 hi everyone im in need of some help i have just bought a 2004 scorpa sy250 the chap i got it off didnt know much so i need some info i want to change the gear oil but dont know the grade ithe last owner gave me a tub of transmition fluid and i didnt know if that was right also does anyone know the correct fuel oil mix thank you i hope someone can help Quote Link to comment Share on other sites More sharing options...
cabby Posted October 5, 2010 Report Share Posted October 5, 2010 I use lite gear oil and 700 mil of. 62.5 mixture per 5 litre or 80 - 1 as it were. Quote Link to comment Share on other sites More sharing options...
thespikeyone Posted October 5, 2010 Report Share Posted October 5, 2010 I was told by the importer (birketts) to run 70:1 fuel mix and for the gearbox Motul 5100 was the best to use as it helps with the clutch. there is also lots of info HERE Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted October 5, 2010 Report Share Posted October 5, 2010 I've used 80mls of synthetic oil to 5 litres of fuel since new on my 05 SY250 and feel happy with that. I keep the air cleaner really clean and lightly oiled which helps to keep the carb free from dust as it's a pain to remove. I've never managed to get more than 400mls of oil in the gearbox. I've tried draining it from the small bolt on the other side and even lying it down but can't get anymore out or in without over filling it. That said, I change the oil quite often and it always looks in clean condition. While you have the bike apart, it's also worth checking that the block ontop of the motor has been ground off. If left standard it wears a hole in the centre box of the exhaust. Quote Link to comment Share on other sites More sharing options...
motosi Posted October 6, 2010 Author Report Share Posted October 6, 2010 thanks guys very helpfull hopefully i can get it ready to fall off at the weekend Quote Link to comment Share on other sites More sharing options...
