feetdown Posted October 6, 2010 Report Share Posted October 6, 2010 I'm going over a season old 2010 250pro I have picked up, need to top up the clutch fluid is it dot4 or mineral Quote Link to comment Share on other sites More sharing options...
jse Posted October 6, 2010 Report Share Posted October 6, 2010 On 10/6/2010 at 7:59 PM, FeetDown said: I'm going over a season old 2010 250pro I have picked up, need to top up the clutch fluid is it dot4 or mineral Mineral oil but a special type just for hydraulic systems (mountain bikes use it in their brake systems), like Magura Blood or Royal Blood. Your dealer should also carry it. Jon Quote Link to comment Share on other sites More sharing options...
gjbiker Posted October 6, 2010 Report Share Posted October 6, 2010 I use LHM (Citreon use a lot of this and there are many brands), cheaper than the Shimano recommended 'bloods' and you'll get a litre for under a fiver if you shop around. It's not hygroscopic like the DOT glycol based fluids (DOT 5 is silicone based, DOT 5.1 isn't - someone needs shot!) so tends to have a good shelf life. Johnsons Baby Oil can be used in an emergency! Whatever you do - don't mix 'em up ! GJ Quote Link to comment Share on other sites More sharing options...
