kenww Posted October 17, 2010 Report Share Posted October 17, 2010 hi ayone know about the rear brake cablefor explorer is it mk1mar 12 inch outer or mk2 15inch outer. alternativly how long are mar swing arms. thanks Quote Link to comment Share on other sites More sharing options...
brian h Posted October 18, 2010 Report Share Posted October 18, 2010 Hi. The Ossa MAR MkI swing arm differs from the later post 1974 MkII Ossa MAR. The post 1974 Mk II has a swing arm 25mm (1.00 ins) longer, giving a longer wheelbase and the requirement for the longer of the two rear brake cables is required. I think the Ossa Explorer would be the same as the Ossa Mar Mk II requiring the longer cable. Both Cables are available in UK from Dave Renham. Hope this helps. Brian H Quote Link to comment Share on other sites More sharing options...
kenww Posted October 18, 2010 Author Report Share Posted October 18, 2010 Brian thank you.do you have contact details for him as web adress didnt work when I tried kenww Quote Link to comment Share on other sites More sharing options...
kenww Posted October 18, 2010 Author Report Share Posted October 18, 2010 On 10/18/2010 at 7:58 PM, kenww said: Brian thank you.do you have contact details for him as web adress didnt work when I tried kenww please forget last message got mixed up with the mostly-spanish guy Quote Link to comment Share on other sites More sharing options...
