lukass Posted February 4, 2005 Report Share Posted February 4, 2005 First up Hi everybody and thanks in advance for your help. The clutch slave cylinder pushes a rod through which pushes a "special rod" (according to diagram) which lifts the clutch basket, there is supposed to be a spacer in between these rods thats listed as D6 is this a 6mm ball bearing? Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted February 4, 2005 Report Share Posted February 4, 2005 Lukass...sorry I cant be much help..but I'm sure someone will be VERY soon....BUT, I have looked at my parts diagram..and all I can say is it sure LOOK like its a ball bearing to me. Maybe its a 6mm one?? Good luck Quote Link to comment Share on other sites More sharing options...
lwm Posted February 7, 2005 Report Share Posted February 7, 2005 Yes it is a ball bearing. And yes you have to have it. Hope you didn't lose it. I did,,, Les Quote Link to comment Share on other sites More sharing options...
lukass Posted February 8, 2005 Author Report Share Posted February 8, 2005 As a matter of fact apparently i did lose it which i am kind of dirty about but it's a stupid idea so i dont feel too bad. Does anyone know why its there surely they could have made one rod 6mm longer. Anyway i opened up an old wheel bearing and amazingly found 6mm balls first try so its all good. Ive not long bought the bike so i stripped and rebuilt it to check everything and that was the only problem i had. Had a few rides around the yard and its going sweet, never realised you could have so much fun hardly moving. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted February 8, 2005 Report Share Posted February 8, 2005 That little spot tales a lot of abuse. That rod pushes something that spins. The bearing is a good idea. Quote Link to comment Share on other sites More sharing options...
