funtrials Posted October 24, 2010 Report Share Posted October 24, 2010 (edited) Help! Got a Michelin "Trials Light" rear tire, used to have the Michelin "X11" rear tire, but don't know what tire pressure to use. With the X11 3.5-4 psi seems to be what people recommend for the rear, but what about the "Trials Light"? Tire pressure for the X11 might not be relevant here, however, unless you've also used the Trials Light specifically, because I'm of the opinion (I sure don't know everything though!) that they just might be quite different in this regard? I'm wondering if the Trials Light, being a less stiff tire might require higher pressure than the 3.5-4 psi for the X11? Edited October 24, 2010 by Funtrials Quote Link to comment Share on other sites More sharing options...
copemech Posted October 24, 2010 Report Share Posted October 24, 2010 (edited) Help! Got a Michelin "Trials Light" rear tire, used to have the Michelin "X11" rear tire, but don't know what tire pressure to use. With the X11 3.5-4 psi seems to be what people recommend for the rear, but what about the "Trials Light"? Tire pressure for the X11 might not be relevant here, however, unless you've also used the Trials Light specifically, because I'm of the opinion (I sure don't know everything though!) that they just might be quite different in this regard? I'm wondering if the Trials Light, being a less stiff tire might require higher pressure than the 3.5-4 psi for the X11? Reports seem to be the sidewals are not as resilient, so if running the rocks I would think a bit more pressure would be due! May cost you in the mud, though! Point being, this technology may have better uses with a minder that adjusts your pressures on the section! Edited October 24, 2010 by copemech Quote Link to comment Share on other sites More sharing options...
the addict Posted October 24, 2010 Report Share Posted October 24, 2010 I tried an Xlite tyre a couple of years ago, ran it at 4.5 pounds in the dry and 3.5 in the mud. Tyre did'nt seem much different to the x11 with these pressures so went back to the cheaper x11 for a while before changing to the might IRC. Quote Link to comment Share on other sites More sharing options...
chewy Posted October 24, 2010 Report Share Posted October 24, 2010 It's a case of horses for courses surely; I recently went riding in the mountains of Andorra, first day set off with an IRC ( the must have tyre of choice where I live and normally ride)at c 6 psi,.... 50 kilometeres and it was shredded, I put a michelin X11 on that night and it ran fine for four similar days but it was quite an eye opener to find the relative "hardness" as you change altitude, what I.m saying is that the pressure outside the tyre affects its performance as much as the pressure inside, its just another factor to keep in mind when settin up your tyres. Quote Link to comment Share on other sites More sharing options...
