Spherical shock bearing
gazzaecowarrior
Hi there
Could anybody tell me why rear shocks often have a spherical bearing. It's not as if the shock moves from side to side in the swing arm or does it twist a bit ? They only go up and down don't they. Why not a roller bearing or ballrace ? The lower shock bearing on my beta is a bugger to get out and usually requires a pneumatic press to get it out which I don't have. It's in such a position that it is allways going to get a lot of abuse from either dirt flying off the tyre or water from the jetwash. Has anybody machined a bush system instead or fitted a different type of bearing which would give a greater longevity and be easier to replace. The spherical bearings are nearly
