trialsrfun Posted January 1, 2014 Report Share Posted January 1, 2014 Hello Deryk thank you for the information & pictures you are posting on TC. Do you have a picture showing the Comerford silencer please. You are right about the original one, my bike ran very poorly with it fitted so most of the time I left it off, big performance gain but triple the noise. Bill Wilkinson said that the one on his bike fell off when crossing the Forth Road bridge then bounced ??? into the river below. Quote Link to comment Share on other sites More sharing options...
farmer58za Posted January 6, 2014 Report Share Posted January 6, 2014 (edited) I have a Pathfinder trials - very good condition but needs TLC (Don't they all?) Is that Honda Cub 90 ignition swop a straight bolt-in? I'd like to do that because the pathfinder ignition is desperate! What is the correct model bing carb used on that model? I have a feeling the one on mine is incorrect. I am going to set up all my vintage 2 strokes to run on Motul 720 (or 800) at 40:1 . Then they all get filled from the same can and the Motul is as good as anything on the market. Regards David Thank you for your reply!! I did have a go replying earlier but it got lost somewhere and i never found it again. What interests me is if you can help on this one is the muffler on the enduro bike is it the same as the trials version as I have five exhausts and most of them are different lengths I think they have been modified in some way or other. Could you let me know or give me a discription of what they are supposed to be as I may have to get a universal muffler and modify it somewhat to fit with some kind of welding or other to attach exhaust to the frame ... With this new synthetic 2 stroke oil (if you use that) what would be the proper mix do you think I have some Motol 2T 720 100% synthetic that can be used to mix, any idea of the ratio 40 to 1 maybe? Tyres I have a 400 x 19 rear enduro tyre (imported from the states with the bike) and not legal here may have to change tyres the others are 400 x 18! the 400 x 19 hits the rear chain guard so not so good. Will let you know when I get it to run as the neighbours wont be too happy especially at 7am in the morning (great fun)!! Do you have a picture of both of your enduros as I would be really pleased to see them together (need to see what goes where on my one ....) if you could that would be great! I have also just found out after changing engines just now that the trials footpegs are attached to the swinging arm bolt (making them higher) thought they were welded, so totally differing position from the enduro and every frame is different, the aluminium mudguard from one enduro will not fit another one as the shape at the back alters I have four frames 3 enduro and 1 trials and they are all at different angles sloping upwards so will have to buy another rear mudguard for my other bike, which could be fun. If you could be of any assistance with this one that would be awesome. Thank you. Edited January 6, 2014 by farmer58za Quote Link to comment Share on other sites More sharing options...
71pathfinder Posted July 21, 2014 Report Share Posted July 21, 2014 I 2 have a 71 Pathfinder … runs but will not move off idle without staling. I am interested in seeing if anyone has a wiring diagram? I think my issue is electrical … help. Quote Link to comment Share on other sites More sharing options...
mark59b Posted May 21, 2020 Report Share Posted May 21, 2020 On 8/8/2014 at 7:44 AM, laird387 said: There are seven good photographs of the Greeves Pathfinder models - plus details of some of the exhaust improvements - in the first issue of the digital magazine, ORRe, available exclusively from 'tc' - see the link in the top right hand corner of the home page. Hi, Old post, can I still see this information please, if so how? Thanks Quote Link to comment Share on other sites More sharing options...
