davetom Posted November 5, 2010 Report Share Posted November 5, 2010 Before I take my bike apart, anyone know the size of the small end in the rod ie the outer size of a new small end bush? Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted November 6, 2010 Report Share Posted November 6, 2010 Hi Guy's Hi Dave. If I get time today I will measure one for you, when I go to work? Regards Charlie. Quote Link to comment Share on other sites More sharing options...
davetom Posted November 6, 2010 Author Report Share Posted November 6, 2010 Thanks Charlie, I`m going down the route of big bore/short stroke 500, using an 86mm xt350 piston that has a 19mm gudgeon pin, so just want to sort out the small end bush I need Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted November 7, 2010 Report Share Posted November 7, 2010 Hi Guy's Hi Dave, Yes that's the route to go, if you want a five hundred,(watch this space). OK,had the rod in me hand yesterday, and got called to do another job, Will check it on Monday. Small end bush of any-size not a problem and can be machined up from a chunk of bronze rod in minuets. Regards Charlie. Quote Link to comment Share on other sites More sharing options...
