marius Posted November 8, 2010 Report Share Posted November 8, 2010 Hi Guys, I am new to this forum and just need some advice please. I have recently bought a TXT300 pro and need to know how to set the chain tension. I have tried to do a search on the forum but didn Quote Link to comment Share on other sites More sharing options...
hrcmonty Posted November 8, 2010 Report Share Posted November 8, 2010 Hi Guys, I am new to this forum and just need some advice please. I have recently bought a TXT300 pro and need to know how to set the chain tension. I have tried to do a search on the forum but didn Quote Link to comment Share on other sites More sharing options...
dadof2 Posted November 8, 2010 Report Share Posted November 8, 2010 Compress your rear suspension until the rear axle, swing arm pivot and gearbox sprocket shaft centres are all in a straight line. At this point your chain will be at its tightest. At this point it should have about 20mm play mid way between the sprockets when the tensioner is held away from the chain. Some people set it a bit slacker to keep the tensioner up a bit away from rocks or accomodate mud build up on the sprockets. Main thing is not to have it too tight or it wrecks you gearbox bearings as well as increasing chain wear. Nor should it be so slack tensioner touches swing arm. Cheers Quote Link to comment Share on other sites More sharing options...
bigfoot Posted November 8, 2010 Report Share Posted November 8, 2010 I think i can say this on here, i may get told off. But one of the site sponsers, Trials uk, if you go to their web site they have a How 2 videos section. Chain tension is part of one of them. Hope that helps. You'll never get told off for promoting a site sponsor. The guys at Trials UK are a good bunch. Quote Link to comment Share on other sites More sharing options...
richt Posted November 8, 2010 Report Share Posted November 8, 2010 I set mine with the wheels off the ground, tension untill 15mm between tension block and the swingarm. I find doing it this way, when the suspension is compressed to where the chain is at the tightest point there is still 20mm slack. Hope this helps. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted November 9, 2010 Report Share Posted November 9, 2010 I agree with RichT..... set it slack so the tensioner is just off the swing arm when in the carpark. My chains last ages so i am finally doing something right. Also use the spray on Maxima Cain Wax.... brilliant stuff and i never have to degrease the chain/sprockets. Quote Link to comment Share on other sites More sharing options...
marius Posted November 9, 2010 Author Report Share Posted November 9, 2010 Thanks guys for all the input and advice. It makes more sense now and I shall be able to adjust the chain properly from now on. Quote Link to comment Share on other sites More sharing options...
atk_nut Posted December 10, 2010 Report Share Posted December 10, 2010 Hey guys, also a new trials guy here. (sort of) Would that tension technique also apply to a 1998 pampera? Thanks. Quote Link to comment Share on other sites More sharing options...
sting32 Posted December 11, 2010 Report Share Posted December 11, 2010 Hey guys, also a new trials guy here. (sort of) Would that tension technique also apply to a 1998 pampera? Thanks. Most likely! I believe we did it the pretty much the same way on the older gasgas trials bikes, just I suggest doing it with wheels off groud (rear wheel at least). since the pamp should be heavier so "at rest" might compress more for static starting point? Quote Link to comment Share on other sites More sharing options...
