Keihin carb help
jitsiejack
  On 11/9/2010 at 7:25 PM, jitsiejack said:
Doing my first maintenance on a 2010 evo and I want to clean the carb out. I have removed the two bowl retaining screws but the bowl does not seem to want to slide down and off - advice please, I don't want to force it or bend float tabs.
Carb must be held upside down then go gentle from there as there is a brass flood tube to negotiate.
Hold the carb upside down and lift the float bowl off. It has to come off at a bit of an angle, but it'll be obvious to you. Be careful not to bend anything when you put it back on and make sure the floats still move by giving the carb a gently shake before you put it back on the bike.
