Tire (tyre) pressures
charliechitlins
I usually run 5 psi in the rear and 12 psi in the front on my 348's. Those pressures may be a little high for some folks, but it prevents spinning the rear tire on the rim and nasty rim dents in the front. Truth be told that unless you are a national class rider you will never notice the difference between 4, 5, or even 6 psi in the rear.
