alan Posted November 12, 2010 Report Share Posted November 12, 2010 before i take the cover off, has any one had similar experiences? The cluch bites when the lever is almost fully out......which leads me to believe that the plates are badly worn. When the bike is cold it is fairly easy to shift gears and find neutral, when its hot it is almost impossibe to do either, which leads me to think that the drum is notched and the plates are dragging.... am i barking up the wrong tree? Quote Link to comment Share on other sites More sharing options...
4stroke Posted November 12, 2010 Report Share Posted November 12, 2010 The stock Tlr clutch is not regarded as being one of the best and all of my Tlr's have proved difficult to get into neutral when hot. Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted November 13, 2010 Report Share Posted November 13, 2010 before i take the cover off, has any one had similar experiences? The cluch bites when the lever is almost fully out......which leads me to believe that the plates are badly worn. When the bike is cold it is fairly easy to shift gears and find neutral, when its hot it is almost impossibe to do either, which leads me to think that the drum is notched and the plates are dragging.... am i barking up the wrong tree? replace clutch plates with cb100n plates.run on mobile one oil.problem nearly solved,well wont be as bad. Quote Link to comment Share on other sites More sharing options...
alan Posted November 13, 2010 Author Report Share Posted November 13, 2010 replace clutch plates with cb100n plates.run on mobile one oil.problem nearly solved,well wont be as bad. many thanks max and 4stroke Quote Link to comment Share on other sites More sharing options...
bobtlr Posted December 20, 2010 Report Share Posted December 20, 2010 you need to adjust the free play on the cable when the clutch gets hot what you have is normal the honda clutches are really bad ones best is not to ride on the clutch all the time on a 200 thats not so hard if the sections are not very severe on a 250 its nearly impossible you will get used to it but there is not a lot to do to it (well there is but its not easy and a lot of work) kevlar plates help a bit but the problem is the clutch operating mechanism is not good enough for trials use dont use synthetic oils that are not suited for wet clutches. best regards bob Quote Link to comment Share on other sites More sharing options...
