hannu Posted November 14, 2010 Report Share Posted November 14, 2010 Just doing an oil change on the front suspension of a 2010 290! Right hand side allen bolt came out without a problem but the Left side just keeps turning without coming out !!!!!!! any ideas anyone ??? Quote Link to comment Share on other sites More sharing options...
lc -rev3 Posted November 14, 2010 Report Share Posted November 14, 2010 I had this problem recently when replacing a fork seal. If you put the lower fork leg in a vice and pull on the stanchion as you're unwinding the bolt it should come out. Hope that helps. Quote Link to comment Share on other sites More sharing options...
hannu Posted November 14, 2010 Author Report Share Posted November 14, 2010 I had this problem recently when replacing a fork seal. If you put the lower fork leg in a vice and pull on the stanchion as you're unwinding the bolt it should come out. Hope that helps. Thanks for that but I have just found something more worrying. The bolts at the bottom of the forks are different sizes the larger one being the Left side I cant get out. I am starting to think that someone has stripped the thread and shoved a larger bolt in !!! Quote Link to comment Share on other sites More sharing options...
hannu Posted November 14, 2010 Author Report Share Posted November 14, 2010 Thanks for that but I have just found something more worrying. The bolts at the bottom of the forks are different sizes the larger one being the Left side I cant get out. I am starting to think that someone has stripped the thread and shoved a larger bolt in !!! Ah, looks like they should be different sizes even though the parts manual states they are the same !!! it just needed a quick buzz with a windy gun !!. Job done Quote Link to comment Share on other sites More sharing options...
