twinkletoes Posted November 14, 2010 Report Share Posted November 14, 2010 Any top tips for an easy fit and keeping them stuck in place? Usually fit them warm to dry bars with some type of grip glue them wire tie them. Usually they work slightly loose after a while, perhaps i am just wringing them too hard as i try to stay on. Just wondering what methods others out there have had sucess with.This particular pair i am about to fit are pro-grips. cheers Quote Link to comment Share on other sites More sharing options...
coriolis Posted November 14, 2010 Report Share Posted November 14, 2010 I always use carb cleaner. Quick squirt and swill around the grip, quickly shake out excess, and shove it on. The carb cleaner makes the inside of the grip go tacky so is kinda like using glue. Done this for the last 10 years, and can only remember one occasion where a grip slipped. Never used wire either. Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted November 14, 2010 Report Share Posted November 14, 2010 Any top tips for an easy fit and keeping them stuck in place? Usually fit them warm to dry bars with some type of grip glue them wire tie them. Usually they work slightly loose after a while, perhaps i am just wringing them too hard as i try to stay on. Just wondering what methods others out there have had sucess with.This particular pair i am about to fit are pro-grips. cheers wd40 works well,i use it all the time. Quote Link to comment Share on other sites More sharing options...
02-apr Posted November 14, 2010 Report Share Posted November 14, 2010 I have found over many years that the best way is to put some masking tape on the bar to give a grippier surface and to increase diameter to suit the particular grip. Lubricate grip with electrical cleaner or similar that will evaporate and not leave any residue. I've never wired grips on having seen too many cut thumbs in the old days when we rode gloveless and folk left the end a bit untidy. It beats me why we still have this problem as the mountain bike guys sorted it years ago with grips that clamp on. I'm surprised nobody has done this as it has to be a way to make money by selling different colour clamps to the sort of people who bother about such things - which seems to be a fair proportion of riders judging by the "bling" that appears to be in demand. Quote Link to comment Share on other sites More sharing options...
jsp Posted November 14, 2010 Report Share Posted November 14, 2010 (edited) i use hair spray, quick squirt in the grips and one on the bars and then leave over night jsp Edited November 14, 2010 by jsp Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted November 14, 2010 Report Share Posted November 14, 2010 I put them on dry using the compressed air method, then wire on. Quote Link to comment Share on other sites More sharing options...
watty Posted November 14, 2010 Report Share Posted November 14, 2010 ive always used exhaust spray paint slips on wet then drys ready to ride 5 mins Quote Link to comment Share on other sites More sharing options...
the addict Posted November 14, 2010 Report Share Posted November 14, 2010 Blow them on dry with an air line, real quick, lockwire them on after Quote Link to comment Share on other sites More sharing options...
greg Posted November 14, 2010 Report Share Posted November 14, 2010 i use hair spray, quick squirt in the grips and one on the bars and then leave over night jsp l'oreal of course Quote Link to comment Share on other sites More sharing options...
lepky1972 Posted November 14, 2010 Report Share Posted November 14, 2010 talcum powder Quote Link to comment Share on other sites More sharing options...
beta_trials Posted November 15, 2010 Report Share Posted November 15, 2010 I have always just used a little soapy water from a spray bottle with the renthal grips i use. I just spray a little on the bars and some in the grip. shake the grip alittle so its coated on the inside and slide the grip on. Let it dry over night and the next day they stay on solid no slipping. Even on hot days. I never used any other tricks with glues or spray paints or even wire tieing them to the bars. I never had a single issue with grips sliding. Also it helps to pay attention to your grips. I dont know about other brands however the Renthal Trials grips Meds i use are sizing on the inside diamiter one being larger than the other. Thus one for throttle and one for plain bar. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted November 15, 2010 Report Share Posted November 15, 2010 Squirt of spray paint on the grip and the bar. Push it on. No lock wire. Done. Quote Link to comment Share on other sites More sharing options...
hrc1 Posted November 15, 2010 Report Share Posted November 15, 2010 Paint does it for me! 2/4 - S3 make clamp on grips.... Quote Link to comment Share on other sites More sharing options...
jsp Posted November 15, 2010 Report Share Posted November 15, 2010 l'oreal of course because im worth it Quote Link to comment Share on other sites More sharing options...
garyc Posted November 15, 2010 Report Share Posted November 15, 2010 Electrical tape has always worked for me. double it over so it's sticky on both sides and wrap it round the handle from the middle outwards, slightly overlapping the tape you've already put on. put some petrol (preferably without 2 stroke oil) in the grip and shake. empty the petrol and quickly push the grip on. Petrol is better than carb/brake cleaner as it doesn't evaporate as fast, giving you more time. never use WD40. super sticky with no wires and no mess and easy to remove and clean up for next time! Quote Link to comment Share on other sites More sharing options...
