txt '00 sprocket sizes
proc
i'm on with changing the chain an sprockets on my '00 200 at the mo it's running a 10t front and a 44t rear
was just wondering if this was the best set up or should i change sizes? :icon_salut:
I think those are stock sizes on the 200. the "right" ratio will depend on your riding style, where are
you having a problem?
Jon
on normal sections it's fine but the bigger hill climbs second isn't enough
but third is too much if you understand what i'm saying? i tend to do most
stuff in first unless it's muddy or a decent climb
Edited by proc
I'm guessing you may want to use a slightly higher ratio. The larger displacement bikes
use a 41 or 42 rear sprocket, you might ask a mate to borrow his/her 42T sprocket
to see if that's what you need rather than buying a new one. I think GasGas also has a 9T
countershaft sprocket if you want to go lower and you could easily swap that on the bike
for those Trials that have the nasty hillclimbs. Trials is one of the very few motorcycle
competitions where we usually run the same gearing for all the venues we encounter so don't
be afraid to change gearing for a specific event.
Jon
