mattsherco290 Posted November 18, 2010 Report Share Posted November 18, 2010 hello there . right then i have a sherco 290 2000 model bought as project got told needed rebuild . ive stripped it down now and all bearings need replacing i can get get all of them exept the big end bearings . i have to buy conrod kit apparently to get them but i dont want to spend this sort of money lol at the moment im hoping the crankshaft pin isd fine . so i want to split the crank measure bearings and match them up . copuld i do this i need help thanks matt Quote Link to comment Share on other sites More sharing options...
chewy Posted November 18, 2010 Report Share Posted November 18, 2010 There used to be people that can do this for you , it requires precice alighnment on re assembly! Try motor engineers in Yellow pages perhaps Quote Link to comment Share on other sites More sharing options...
copemech Posted November 19, 2010 Report Share Posted November 19, 2010 First question is why you need to do this? Is there any percievable monement up/down in the exhisting one? Is it rough feeling when rotating rod? If so, you need a kit! Otherwise not! Quote Link to comment Share on other sites More sharing options...
mattsherco290 Posted November 19, 2010 Author Report Share Posted November 19, 2010 yer minimal movement up and down and slihtly side to side . bearings are goosed lol do you know any cheap kits ? cheers ive sent crank away to get looked at gettin it reconditioned cheers Quote Link to comment Share on other sites More sharing options...
copemech Posted November 20, 2010 Report Share Posted November 20, 2010 yer minimal movement up and down and slihtly side to side . bearings are goosed lol do you know any cheap kits ? cheers ive sent crank away to get looked at gettin it reconditioned cheers No cheap kits, bite the bullet on this! If it is done it is doone. Should always be some side to side, btw. Most cycle shope can press and true the crank, I done tons back in the day. Nothing too special here for a good tech. Quote Link to comment Share on other sites More sharing options...
mattsherco290 Posted November 20, 2010 Author Report Share Posted November 20, 2010 No cheap kits, bite the bullet on this! If it is done it is doone. Should always be some side to side, btw. Most cycle shope can press and true the crank, I done tons back in the day. Nothing too special here for a good tech. hi mate yeah whats the rough cost of it now anyway mate ?? just incase they try con me haha and whats the best stuff to use to clean the engine and what are sherco like for riding power wise ? im new to it hah Quote Link to comment Share on other sites More sharing options...
copemech Posted November 20, 2010 Report Share Posted November 20, 2010 hi mate yeah whats the rough cost of it now anyway mate ?? just incase they try con me haha and whats the best stuff to use to clean the engine and what are sherco like for riding power wise ? im new to it hah Best I recall, we would charge for one hour's labor at the prevailing rate to press a crank. Mineral spirits paint thinner(for oil based paint) is probably your best cleaner, then a blow dry. Anything too strong like laquer thinner will take the paint off the cases. Quote Link to comment Share on other sites More sharing options...
mattsherco290 Posted November 24, 2010 Author Report Share Posted November 24, 2010 Best I recall, we would charge for one hour's labor at the prevailing rate to press a crank. Mineral spirits paint thinner(for oil based paint) is probably your best cleaner, then a blow dry. Anything too strong like laquer thinner will take the paint off the cases. okay buddy thaanks , any help on rebuilding my engine now i need to find out torque settings and everything else to put it back together thanks mate help would be great ta matt Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 25, 2010 Report Share Posted November 25, 2010 Look at the top of the page for the service manual links, they have pretty much everything you could possibly need in them Quote Link to comment Share on other sites More sharing options...
copemech Posted November 26, 2010 Report Share Posted November 26, 2010 If I had to give tips to anyone on these motors, they would be: Scribe the shaft and nuts on the therr major components, Flywheel, Primary drive geer, and Clutch hub prior to disassembly. This makes it easy to bring them back up to original or ever so slightly beyond position and torque using a rattle gun for quick assembly. Without, one would need a flywheel holder and clutch holder to apply proper torque. Most critical being the clutch hub, which is less and will strip. Go back with the Viton main seals from Splatshop, as compared to the standard nitrile. Be sure you keep all your little washers in proper relation. Quote Link to comment Share on other sites More sharing options...
mattsherco290 Posted November 28, 2010 Author Report Share Posted November 28, 2010 If I had to give tips to anyone on these motors, they would be: Scribe the shaft and nuts on the therr major components, Flywheel, Primary drive geer, and Clutch hub prior to disassembly. This makes it easy to bring them back up to original or ever so slightly beyond position and torque using a rattle gun for quick assembly. Without, one would need a flywheel holder and clutch holder to apply proper torque. Most critical being the clutch hub, which is less and will strip. Go back with the Viton main seals from Splatshop, as compared to the standard nitrile. Be sure you keep all your little washers in proper relation. okay thanks buddy . can anyone help me i want a full gasket set for sherco 290 2000 model ive found 1 for 38 pounds . is that cheap what would you say trial riders ?> Quote Link to comment Share on other sites More sharing options...
copemech Posted November 29, 2010 Report Share Posted November 29, 2010 okay thanks buddy . can anyone help me i want a full gasket set for sherco 290 2000 model ive found 1 for 38 pounds . is that cheap what would you say trial riders ?> Could be, all depends upon what's in it! Once again, might call someone like Chris at Splatshop to compare. Some gaskets you may not need, depending? Quote Link to comment Share on other sites More sharing options...
mattsherco290 Posted December 3, 2010 Author Report Share Posted December 3, 2010 Could be, all depends upon what's in it! Once again, might call someone like Chris at Splatshop to compare. Some gaskets you may not need, depending? hey there right alpha bearings have got my crank , i need a conrod kit unless i get recondition crank from somewhere if its possibly cheaper ?? any help ? Quote Link to comment Share on other sites More sharing options...
