gaz_hay Posted November 20, 2010 Report Share Posted November 20, 2010 Hi has above is there any way i can adjust the clutch within the engine is there a guide to follow? Thanks Quote Link to comment Share on other sites More sharing options...
bigwilly Posted November 20, 2010 Report Share Posted November 20, 2010 Now I may well be wrong as I've not taken mine apart... yet. Never the less 'normal' Yamaha doings is such that you can adjust a 10mm (ish) nut on the end of the push rod in the centre of the clutch. Often you can hold the push rod steady with a cross head screwdriver. Be warned though little adjustments make a big differance. Even if the above is not the case on your ty you can see the condition of the clutch whilst your there Quote Link to comment Share on other sites More sharing options...
