cooper956 Posted November 20, 2010 Report Share Posted November 20, 2010 i got on my bike the other day only to find there was no clutch so there was feel to the lever but haveing not riden in in a while was unsure if it was normal so i tryed to bleed it then had nothing iv now bleed it sort of but removeing the circlip in the plunger it works but drags bad how do i bleed it proply i tryed rev bleding but nothing wound go into the res without the circlip removed i bleed it with the leaver removed also. hope someone can follow this and help? Quote Link to comment Share on other sites More sharing options...
chewy Posted November 20, 2010 Report Share Posted November 20, 2010 Be sure that the slave cylinder ( on a gasser it's a piston inside the clutch cover/casing) is primed ,if you have air in here between the bleed nipple and the piston it wil always simply compress. It could be that the piston in the master cylinder is sticking;.. seals may have expanded. Does your bike use/need mineral oil or brake fluid? Quote Link to comment Share on other sites More sharing options...
greg Posted November 20, 2010 Report Share Posted November 20, 2010 I used to have a 96 321, i found the best way to sort any problems was with a lump hammer. Quote Link to comment Share on other sites More sharing options...
