gaz_hay Posted November 26, 2010 Report Share Posted November 26, 2010 Hi, want to know is there any way of finding if my ty has the wiring for a front light? There are 2 wires taped up under by the carb and wondering what these are for any ideas? AS i plan to fit a light to the front, so wondering how to go about it. Thanks, for replies Quote Link to comment Share on other sites More sharing options...
alan_nc Posted November 26, 2010 Report Share Posted November 26, 2010 You have several options. How many wires are coming out of the gromet at the top of the left side case? Should be one going to the secondary coil (to provide spark), probably one going to the kill switch and if you have two more - one for the headlight and one for the taillight. Put a VOM (Volt/Om Meter) on the wires while the bike is running and see what the output is. If the bike isn't running yet remove the left side case and look inside the flywheel slots to see if it is fitted with a lighting coil. There will be two coils inside the flywheel - one to the front of the bike one toward the rear. The front one provides spark and the rear, if fitted, provides power for the lights. You may have to pull the flywheel to make sure the lighting coil is wired up correctly. It would have come from the factory with both coils but many riders remove the lighting coil to save weight and avoid complication. HTHs Alan Quote Link to comment Share on other sites More sharing options...
gaz_hay Posted November 26, 2010 Author Report Share Posted November 26, 2010 thanks for the reply i will look on the weekend and use a multimeter thanks Quote Link to comment Share on other sites More sharing options...
gaz_hay Posted November 27, 2010 Author Report Share Posted November 27, 2010 checked the wires 2day and there are 5 goin out of the casing 3 of them goin to spark plug relay thing and the kill switch 2 others are tapped up under the bike by the carb but when started there is no power to the 2 wires? Quote Link to comment Share on other sites More sharing options...
alan_nc Posted November 27, 2010 Report Share Posted November 27, 2010 Now you have to pull the side cover off and see if you have a lighting coil installed. If you do then you need to see if the wires are connected. Good luck. Alan Quote Link to comment Share on other sites More sharing options...
