steam and water from rad
rustybay
Hi there
Ive got a 1995 jtr that when i start up will run ok for a short time, then steam and coolent will come out of the over flow.
IF i rev up, then back off more fluids come out. The impler is turning and the fan is also working.
could this be a gasket
can anyone help ?
regards
wayne
You need to replace the two rubber 'O' rings that seal the water jacket between the cylinder and cylinder head. When these 'give up' the cooling system is pressurised and gives the symptoms you describe. A fairly easy job; no need to remove the cylinder, just the head.
it can be head gasket or whatever seals the head - gas leaks into the cooling system expanding and pressurising it until the cap can't take it and it starts to come out
if you keep the cap on, fit a pipe to your overflow and then put it into a clear bottle with some water in you should see bubbles coming out of the pipe if it is the head blowing
hope that helps
tony
