markieboi Posted December 3, 2010 Report Share Posted December 3, 2010 Hi all, I'm just on changing the front and rear wheel bearings on my 02 290, I've managed to get the spacers out ok but how do you actually get the old bearings free from the hub? I'm hoping there's some kind of easy trade secret for this........ Cheers in advance guy's. Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted December 3, 2010 Report Share Posted December 3, 2010 heat up alloy hub with blow lamp.how did you get spacers out without taking bearings out? Quote Link to comment Share on other sites More sharing options...
markieboi Posted December 3, 2010 Author Report Share Posted December 3, 2010 On 12/3/2010 at 9:03 PM, max1956bikes said: heat up alloy hub with blow lamp.how did you get spacers out without taking bearings out? To be honest the spacers came out with very little effort, just eased them out with a screw driver, but the bearings themselves are stuck fast. I'll try heat but I can't see how you get them out the hub as in do you knock them out with a screw driver or some other way? Quote Link to comment Share on other sites More sharing options...
fantic200 Posted December 3, 2010 Report Share Posted December 3, 2010 On 12/3/2010 at 9:22 PM, markieboi said: To be honest the spacers came out with very little effort, just eased them out with a screw driver, but the bearings themselves are stuck fast. I'll try heat but I can't see how you get them out the hub as in do you knock them out with a screw driver or some other way? i would just use boiling water over the hub, it will be enough to make the hub expand. Quote Link to comment Share on other sites More sharing options...
copemech Posted December 4, 2010 Report Share Posted December 4, 2010 One of the lads a while back had an interisting suggestion. He used an expanding anchor bolt such as used in concrete anchors to lock into the stubborn bearing. Gives you something to beat it out then!!!! I think they are 17mm or roughly 11/16 in. Quote Link to comment Share on other sites More sharing options...
gjbiker Posted December 4, 2010 Report Share Posted December 4, 2010 Not a trials wheel I know but the principal is much the same... Personally; I use a long flat end punch - not a screwdriver. Blow torch, heat gun, boiling water all help but 9 times out of 10 you don't need any heat at all. I've used Copeys suggestion of a rawl bolt and it works a treat (sometimes the inner spacer tube doesn't have enough tolerance (freeplay) to allow punching out the first bearing).Welding some scrap to the inner race also works. I use the old bearing to aid tapping in the new one rather than a socket. There are times that the inner race will punch out and leave the outer race still in the wheel - then it gets more interesting! DON'T forget to put the inner spacer back in before you tap in the last bearing! Have fun GJ Quote Link to comment Share on other sites More sharing options...
hrcmonty Posted December 4, 2010 Report Share Posted December 4, 2010 M10 rawl bolt works perfectly, stick it in, expand it fairly tight, get a long bar from the other side of the wheel and get hammering. If the bar is knocking on the threaded part of the rawl bolt, it also forces the little collar further into the housing, thus making it expand whilst knocking. works a treat. or buy a bearing puller. Quote Link to comment Share on other sites More sharing options...
markieboi Posted December 4, 2010 Author Report Share Posted December 4, 2010 Brilliant, thanks loads for all the help and suggestions. I never thought about a Rawl bolt. I'll give it a go with that plus heat. Thanks again. Quote Link to comment Share on other sites More sharing options...
firedfromthecircus Posted December 4, 2010 Report Share Posted December 4, 2010 On 12/4/2010 at 5:08 AM, gjbiker said: There are times that the inner race will punch out and leave the outer race still in the wheel - then it gets more interesting! If your bearing comes apart and you need to just remove the outer race get a welder (arc is easiest for this job) and just run three evenly spaced short beads on the inside of the race (where the bearings used to run). The race will almost fall out after that. Quote Link to comment Share on other sites More sharing options...
stilly Posted December 4, 2010 Report Share Posted December 4, 2010 I got mine out with a long punch knock it from the inside, soak them with plenty wd40 worked well f me back and front wheels Quote Link to comment Share on other sites More sharing options...
baldilocks Posted December 4, 2010 Report Share Posted December 4, 2010 I do this by removing the wheel spacers then using a socket thats a snug fit inside the bearing but wont go throught the centre tube I tap the bearing through the opposite side of the hub. Once the centre tube has some play you can use a long screwdriver or rod. I'm too tight to buy a rawl plug Quote Link to comment Share on other sites More sharing options...
eastcoasthopper Posted December 15, 2010 Report Share Posted December 15, 2010 On 12/4/2010 at 8:38 PM, Baldilocks said: I do this by removing the wheel spacers then using a socket thats a snug fit inside the bearing but wont go throught the centre tube I tap the bearing through the opposite side of the hub. Once the centre tube has some play you can use a long screwdriver or rod. I'm too tight to buy a rawl plug That's the same thing I do. But on my '06 the center spacer is shouldered so I couldn't get it off center. I ended up mushing the end of the spacer a bit, took a while with a rat tail file to clean it up so the axle would slide through easily. I'm going to try that rawl bolt thing, that sounds like the BOMB! Quote Link to comment Share on other sites More sharing options...
