hardassfunk Posted December 5, 2010 Report Share Posted December 5, 2010 Picked up a Montesa yesterday as a project dont know alot about it,it was advertised as a Montesa 250 but he says it could be a 350.Came with a massive amount of spares such as wheels forks cases and what looks like a newer model engine? Any help in idenifying which model it is? Heres a few pics: http://www.facebook.com/photo.php?pid=5761488&l=89c0322a9a&id=772753777 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted December 5, 2010 Report Share Posted December 5, 2010 Picked up a Montesa yesterday as a project dont know alot about it,it was advertised as a Montesa 250 but he says it could be a 350.Came with a massive amount of spares such as wheels forks cases and what looks like a newer model engine? Any help in idenifying which model it is? Heres a few pics: http://www.facebook.com/photo.php?pid=5761488&l=89c0322a9a&id=772753777 Gary I could only find one very dark photo of the LH side of the top of the motor on FB. That photo looks like a Cota 348 motor (310cc and made from 1976 to 1978) David Quote Link to comment Share on other sites More sharing options...
belldane Posted December 6, 2010 Report Share Posted December 6, 2010 Hi think David is right but do you have an engine number as it could also be a 349 motor. Apart from the internals it is a very similar motor to the 348 Quote Link to comment Share on other sites More sharing options...
vintagecota Posted December 6, 2010 Report Share Posted December 6, 2010 Hi think David is right but do you have an engine number as it could also be a 349 motor. Apart from the internals it is a very similar motor to the 348 349s have different side covers. The bike is a 247 from '74-'75 probably. I can narrow it down with a frame/engine number. Quote Link to comment Share on other sites More sharing options...
hardassfunk Posted December 6, 2010 Author Report Share Posted December 6, 2010 349s have different side covers. The bike is a 247 from '74-'75 probably. I can narrow it down with a frame/engine number. Thanks for the replies I will get back with some better pictures,engine and frame numbers when i get the chance.Would the engines be interchangable? as the bottom end has gone on the engine fitted Quote Link to comment Share on other sites More sharing options...
vintagecota Posted December 7, 2010 Report Share Posted December 7, 2010 Anything can be done, but it's not simple. The case mounts might be the same, but the exhaust exiting straight out the front of the 348 won't clear the single downtube on the 247. Quote Link to comment Share on other sites More sharing options...
hardassfunk Posted December 8, 2010 Author Report Share Posted December 8, 2010 Been out in my workshop today and did abit of work on the Montesa.Took the original engine out (no numbers apart from 86 86 on the rear engine mount)I fitted the spare engine 51M15210 the engine slotted in the original mounts so that could be a route I take.The frame number is 21M13371.In amongst the spares was a left hand engine crank case with the numbers 51H00047,looks as though the crank case covers to match this but no internals,other spares included were 3 sets of forks,Montesa 348 alloy tank and seat unit,smaller alloy tank,afew silencers,pair of wheel,swingarm,head identical to the one on 51M15210 and various other small bits and bobs.Now the problem I have with fitting the spare engine is I need to find the matching carb and exhaust so im thinking of selling the spare engine and rebuilding the original but that depends on what damage i find when i strip the engine.Hopefully heres some more pics: http://www.facebook.com/album.php?aid=252562&id=772753777&l=55f08fac5a Quote Link to comment Share on other sites More sharing options...
vintagecota Posted December 9, 2010 Report Share Posted December 9, 2010 (edited) The 247 is a '74, the 348 engine is a '78. Did you notice that you can't fit the exhaust, or do you have the barrel on yet? Just for comparison, that left-side case and cover are from a 349 engine. Edited December 9, 2010 by vintageCota Quote Link to comment Share on other sites More sharing options...
hardassfunk Posted December 9, 2010 Author Report Share Posted December 9, 2010 The 247 is a '74, the 348 engine is a '78. Did you notice that you can't fit the exhaust, or do you have the barrel on yet? Just for comparison, that left-side case and cover are from a 349 engine. Thanks alot for this info!! I did have a quick look today and fitting the 348 engine is a definate no due to the exhaust position as the frame would need modification. On the up side I started stripping the original engine and im 99% sure that it can be rebuilt Do they usually have no engine numbers? I did find another number inside the sprocket cover 34.60.002W Quote Link to comment Share on other sites More sharing options...
vintagecota Posted December 10, 2010 Report Share Posted December 10, 2010 If I recall correctly the 247s have the engine number up at the front on top of the right-side case... it's been a while since I got rid of mine. Quote Link to comment Share on other sites More sharing options...
wobbler Posted December 11, 2010 Report Share Posted December 11, 2010 Gary, I'm from Carlisle and might know someone with some 247 spares that might help you . It was the same style as yours with the clutch arm underneath - I have a later one 79 - that's got the clutch arm on top of the casing. Give me a shout on 07801 447 616 and i'll give you his number Cheers Wobbler (Paul) Quote Link to comment Share on other sites More sharing options...
hardassfunk Posted December 15, 2010 Author Report Share Posted December 15, 2010 Not alot of progress due to work :/ Looking at pics on google I see some bikes have a silver frame and some have black,what would the correct colour be for my model also what chance do I have of finding some original front and rear lights? Quote Link to comment Share on other sites More sharing options...
vintagecota Posted December 15, 2010 Report Share Posted December 15, 2010 Frames went from gray to black at bike number 21M13107, so yours should be black. Quote Link to comment Share on other sites More sharing options...
hardassfunk Posted December 19, 2010 Author Report Share Posted December 19, 2010 Stripped the engine down yesterday . . . top end seems fine P.I.T.A getting the recessed barrel nuts out! what type of tool usualy fits? I used a oversize Torx bit as they were rounded off! can new ones be bought? Looks like the only part of the engine that needs repairs is the con rod as the big end bearing is non existant.I've removed the pressure plate and friction plates but cant remove the clutch basket? maybe once i find my Puller set i should succeed.Where in the UK can i get the crank rebuilt? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted December 20, 2010 Report Share Posted December 20, 2010 The cylinder nuts are 7mm internal hex and yes you can buy new ones Quote Link to comment Share on other sites More sharing options...
