Leaking oil level window
petrs
Hello,
does anyone know, how to repair leaking oil level window on Sherco 320 4T 2008?
I have special loctite silicon to seal engine block, head, etc. but I don't know, if I can put the window out without destroy it.
Or is there any better way to solve this problem?
Thank you very much.
Best Regards
Petr.
I think if I had to I would clean the area extremely well with solvent, with bike laying on it's side. Then I would apply a thin coat of clear silicone, then let set for 24 hours. If that's helpful.
Hello rockyrider,
thank you for reply, but I have red silicon and it will not look nicely. Don't you know, if I can put the window out from cover without destroy it?
Hello rockyrider,
it used to leak on my beta, i'm sure it could be tightened up (threaded). just a thought.
