beamish suzuki
midlife
As far as I'm aware they're no longer avaliable, when my Beamish needed new bushes I got some new ones turned out of nylon and they do the job and should be longer lasting.It also worked out a lot cheaper than buying the swingarm repair kit already mentioned. The hard part is taking the old ones out, the way I did it was with a lot of heat to burn the rubber inners out and then carefully cut the outer with a dremel multi and then punch the remains out with a chisel.Hope this helps.
  • 1 month later...
