midlife Posted December 10, 2010 Report Share Posted December 10, 2010 Does any one know where to get bushes for the swinging arm, its the metal elastic type.I am thinking that when the frames were made beamish used what was available like off a car suspension. Quote Link to comment Share on other sites More sharing options...
scorpa250 Posted December 10, 2010 Report Share Posted December 10, 2010 Hi, go to the beamish owners club. go to Jims parts,he has a swinging arm repair kit for sale .Regards Paul Quote Link to comment Share on other sites More sharing options...
andy m Posted December 10, 2010 Report Share Posted December 10, 2010 http://www.beamishownersclub.com/_sgg/m9m1_1.htm Quote Link to comment Share on other sites More sharing options...
turps Posted December 11, 2010 Report Share Posted December 11, 2010 As far as I'm aware they're no longer avaliable, when my Beamish needed new bushes I got some new ones turned out of nylon and they do the job and should be longer lasting.It also worked out a lot cheaper than buying the swingarm repair kit already mentioned. The hard part is taking the old ones out, the way I did it was with a lot of heat to burn the rubber inners out and then carefully cut the outer with a dremel multi and then punch the remains out with a chisel.Hope this helps. Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted January 16, 2011 Report Share Posted January 16, 2011 You can modify the swing arm to take other bushes but the original metalastick ones had no moving parts and lasted on average 30+ years. I am machining another 10 sets with stainless nuts, spindles, spacer and washers in the next few weeks. Quote Link to comment Share on other sites More sharing options...
