godzilla Posted December 14, 2010 Report Share Posted December 14, 2010 Im about to start looking at my Fantic 240 clutch as its a little grabby, will the cover come off in situ? it looks tight and i cant quite tell if the motor needs to be lifted a little so the bottom front bolt and cover will clear the frame. Quote Link to comment Share on other sites More sharing options...
lee harris Posted December 14, 2010 Report Share Posted December 14, 2010 (edited) yes it should do as the original 240 had a small clutch drum and cover... if it is a 241 or even a 301 or later, the engine mounts will need loosening...ther clutch basket and hence cover were bigger diamente lee Edited December 14, 2010 by Lee Harris Quote Link to comment Share on other sites More sharing options...
