Honda TLR200 Fork Yoke Swap
esteve
Does anybody know (definitely) if RTL250S fork yokes can be used on a TLR200?
is the stem length and diameter the same re fitting into the headstock ?
is the distance between the stanchion centres the same ?
is there any geometry change ?
Thankyou
Edited by Esteve
  • 1 month later...
Thankyou
Not a straight forward swap, steering stem is shorter,
and if you use a longer stem , fork leg alignment between top and bottom yoke is not good,
also fork legs will be slightly more forward, so longer wheelbase .
Edited by motomike
Thankyou for motomike. You've saved me from acquiring some RTL yokes in the off chance they would fit (seen two sets on ebay in as many months; seems a shame to break up an RTL)
