247 Cota HELP!
charliechitlins
This is a big bummer, I think.
Broken kick shaft.
Between the 2 splines where the kicker arm goes on, there is a hole through the shaft making it very weak.
Is this factory, or a cob job by a previous hammer-and-tongs man to secure a stripped shifter?
Either way, the end of the shaft snapped off.
Does this mean split the cases to install a new shaft?
Is a new shaft even available?
I wonder how the new girlfriend feels about engines on the kitchen table....
Yep. The primary gear on the clutch side will either come off very easily with a 3 jaw puller or can be very stubborn to get off. If it is stubborn you will need to put as much pressure as you can on the puller and heat the gear up with an oxy. Just watch it as it can come out at a hundred miles an hour. Apart from that the rest is fairly straight forward unless the gearbox collapses on you as you split the cases and end up with a pile of gears and rollers at the bottom of the case. Have fun
