whizzy Posted December 27, 2010 Report Share Posted December 27, 2010 I'm just puting the 200 back together again, it's been apart for a while. i can't for the life of me remember how to get the exhaust back in place. Help. Quote Link to comment Share on other sites More sharing options...
02-apr Posted December 27, 2010 Report Share Posted December 27, 2010 It's been a decade or two but I seem to recall starting with the system facing backwards and threading the pipe through the downtubes then twisting it round, or vice versa. Quote Link to comment Share on other sites More sharing options...
totalshell Posted December 27, 2010 Report Share Posted December 27, 2010 seat and tank off and thread it through from the rear the front mount to the engine is the tricky bit dont fasten exhaust to frame until it is on at the exhaust cylinder head.. Quote Link to comment Share on other sites More sharing options...
westyfield Posted December 27, 2010 Report Share Posted December 27, 2010 ....I've given up trying to sort this chinese puzzle in the past and just unbolted and removed the cylinder head.. Quote Link to comment Share on other sites More sharing options...
furse Posted December 27, 2010 Report Share Posted December 27, 2010 Dont put the engine bolts in until exhaust is roughly in position, this will let the engine drop a little bit, giving you half an inch. Quote Link to comment Share on other sites More sharing options...
whizzy Posted December 27, 2010 Author Report Share Posted December 27, 2010 On 12/27/2010 at 7:20 PM, Westyfield said: ....I've given up trying to sort this chinese puzzle in the past and just unbolted and removed the cylinder head.. I looked at that way but you can't tighten one of the head bolts then. Anyway i've done it now :-) All engine bolts in postion, no tank or seat fitted. I just walked away, returned a hour later and it went on first time. i've no idea how to explain how i did it. Thanks for your replies/sympathy. Quote Link to comment Share on other sites More sharing options...
cfraser Posted December 29, 2010 Report Share Posted December 29, 2010 (edited) On 12/27/2010 at 7:09 PM, totalshell said: seat and tank off and thread it through from the rear the front mount to the engine is the tricky bit dont fasten exhaust to frame until it is on at the exhaust cylinder head.. Just as Totalshell said....take your time and think about it as you are threading it forward from the rear. I just re-installed mine this evening. Once you get the hang of it, it can be done in a minute or so. Just twist and pull and angle the front through the frame, twist and take your time..once the front of the exhaust clears the front frame downtubes, twist and bolt it all together. Sometimes you do just have to walk away for a few minutes. It's good to hear you have it re-installed...as you noticed, no need to remove the head, carb, or airbox. Happy New Year, Carl Edited December 29, 2010 by cfraser Quote Link to comment Share on other sites More sharing options...
