Tubed front tyre onto 305 tubless rim
shazsdad
  • 4 months later...
Hi
Can you fit a tubed front tyre onto a tubeless front rim as fitted to 305 model Fantics. I will need to drill the rim for a security bolt. Will it stay on or slip down in to the well once the pressure is reduced. Thanks
Hi...I've got the same issue with a 303, did you get the problem sorted in the end ? rgds Mike.
