nath15804 Posted December 31, 2010 Report Share Posted December 31, 2010 Hi, recently my sy has atarted smoking quite badly, oil amount has always been kept the same, iv changed the plug bt still doing it, what could it be? :madnoel: Quote Link to comment Share on other sites More sharing options...
andy m Posted December 31, 2010 Report Share Posted December 31, 2010 Hi, recently my sy has atarted smoking quite badly, oil amount has always been kept the same, iv changed the plug bt still doing it, what could it be? :madnoel: Is it losing gearbox oil?? If so it will be the crank case oil seal on the clutch side. Check the water level as well. Quote Link to comment Share on other sites More sharing options...
nath15804 Posted January 1, 2011 Author Report Share Posted January 1, 2011 Is it losing gearbox oil?? If so it will be the crank case oil seal on the clutch side. Check the water level as well. would it affect the water level? im going to give it a service tommorow and see whats what. cheers Quote Link to comment Share on other sites More sharing options...
