haggerthegreat Posted January 2, 2011 Report Share Posted January 2, 2011 (edited) Just notice when checking clutch that water is mixing with oil in the gearbox,i think it must be leaking through the water pump amd was wanted to no if it is easy enough of a job to sort and wat is involed in changing the seal. Also when taking about the clutch wound anyone know the thickness off the plates should be. 1999 270 txt Edited January 2, 2011 by haggerthegreat Quote Link to comment Share on other sites More sharing options...
