bigman Posted January 3, 2011 Report Share Posted January 3, 2011 Hi Guys I have read on here that the 2003 Rev 3's tend to feel a little under powered compare to other years of rev 3, is there a good reason for this, and can it be sorted by altering carb setup etc? The bike would be my first trials bike in 7 years (had a 97 techno before starting bike trials) although I am quite a heavy guy, around 19st at the moment, although that is slowly reducing. Thanks Adam Quote Link to comment Share on other sites More sharing options...
mobbster Posted January 3, 2011 Report Share Posted January 3, 2011 Hi Bigman... You need to be looking for a 270cc and buy the newest one you can afford You will have to get an uprated rear spring made up as these are only set up for a 12stone max rider from the factory. (I would ring a place like BVM at stroud) and see if they can point you in the right direction for a spring. Steve saunders does them for the beta evo he may also know. All the best Cheers Quote Link to comment Share on other sites More sharing options...
