Fork and dust seals
hilltopcycleatv
As far as the seals go, a seal is pretty much a seal. Get out your Mic and measure the ones on the Sherco, inside diameter, outside diameter, height. Match em with something you have and you're good to go. After you put the new seals in, put a set of neoprene fork slider protectors on to keep crap from getting in there and ruining them again. Protects the sliders from light damage against rocks and stuff too. I've never had a seal fail after I put the protectors on.
