hilltopcycleatv Posted January 5, 2011 Report Share Posted January 5, 2011 Is there any aftermarket fork and dust seals that will work on my 04' 2.9 ? I have some seals for other bikes on the wall and would like to use them if they would work . Has anyone done any research on what ones will work ? Thanks, Raz Quote Link to comment Share on other sites More sharing options...
ridgrunr Posted January 5, 2011 Report Share Posted January 5, 2011 As far as the seals go, a seal is pretty much a seal. Get out your Mic and measure the ones on the Sherco, inside diameter, outside diameter, height. Match em with something you have and you're good to go. After you put the new seals in, put a set of neoprene fork slider protectors on to keep crap from getting in there and ruining them again. Protects the sliders from light damage against rocks and stuff too. I've never had a seal fail after I put the protectors on. Quote Link to comment Share on other sites More sharing options...
hilltopcycleatv Posted January 5, 2011 Author Report Share Posted January 5, 2011 I am thinking these will work . Does anyone know for sure ? http://www.denniskirk.com/jsp/product_catalog/Product.jsp;jsessionid=WLVXC5CMAPKEDQFIDYESM4WAVAPAQIV0?store=&skuId=14230&mmy=#fitment Thanks, Raz Quote Link to comment Share on other sites More sharing options...
tony27 Posted January 6, 2011 Report Share Posted January 6, 2011 All balls do seals but not wipers, also do linkage kits which I have 1 sitting at the local KTM dealer to collect Seal kit number is 55-137, fits a lot of early 80s Kawasakis & quite a few Yamahas Quote Link to comment Share on other sites More sharing options...
