stilly Posted January 6, 2011 Report Share Posted January 6, 2011 Hi all I need some help on where to set the stator plate on my sherco 250 04, dose the tick Mark on the plate line up with the line on the casing as I can see a line on mine or am I wrong, can I have it advanced or not any help would be great. Quote Link to comment Share on other sites More sharing options...
tony27 Posted January 7, 2011 Report Share Posted January 7, 2011 Pretty sure the 04 runs leonelli ignition so the manuals that are linked at the top are what you need to use, the line on the stator plate should line up with the righthand edge of the mounting lug. Quite a few threads here that have photos showing the set up, Copemech has a very good phot explanation of exactly how to advance or retard the timing Quote Link to comment Share on other sites More sharing options...
stilly Posted January 7, 2011 Author Report Share Posted January 7, 2011 I found a post, try waynes help, it's now set to standard setting I will keep it there, no point in trying to walk before I can crawl cheers for the help Quote Link to comment Share on other sites More sharing options...
