Timing Peg
caddabs
Seems I recall it being a 3.5 or 4mm rod. I suppose a drill bit world work.
The picture in the Waynes help thing is worth a thousand words. You can look at the gap in the end of the top screw slot to judge where to put it without all the scientific measure(which for matters of simplification I think the actual finding of TDC here may be a bit lacking)
All in all +- 1mm makes little difference unless you are advancing it, which becomes a bit more critical. :rolleyes:
