tlr200 kick start
alan
before i take the cover off, has any one experienced this ?
when kicking the bike over the kick start lever does not return fully home.
There appears to be a tight spot when it engages with the decompressor mechanism.
is there a known fix ?
i have had exactly the same thing on my xl185, there could be 2 things:-
the return spring is damaged or broken or the kick start gears are damaged and jaming.
the first one is quite an easy fix, the second could be expensive as if the kick gears go too far they can make a hole in the inner casing.
i totaled up my damage and it came to over
