blocky Posted January 13, 2011 Report Share Posted January 13, 2011 Hi. Just taken the clutch cover off my ty 250 twinshock and was surprised to see that the crankshaft oil seal was facing with the spring outwards. Is this correct ? Quote Link to comment Share on other sites More sharing options...
alan_nc Posted January 13, 2011 Report Share Posted January 13, 2011 (edited) This link should give you a link to a drawing of the seal assembly. http://www.yamaha-motor.com/sport/parts/home.aspx Couldn't get it to go to the specific page. Just click on the three blocks at the top and fill in your bikes information. There will be a menu on the left, about the third item down is the crank. Shows a good picture. HTH Alan Edited January 13, 2011 by Alan_nc Quote Link to comment Share on other sites More sharing options...
blocky Posted January 13, 2011 Author Report Share Posted January 13, 2011 This link should give you a link to a drawing of the seal assembly. http://www.yamaha-motor.com/sport/parts/home.aspx Couldn't get it to go to the specific page. Just click on the three blocks at the top and fill in your bikes information. There will be a menu on the left, about the third item down is the crank. Shows a good picture. HTH Alan Thanks Alan. Took a look but still not 100% sure even after looking at the diagram Quote Link to comment Share on other sites More sharing options...
mrb505 Posted January 13, 2011 Report Share Posted January 13, 2011 Have a look here hopefully it might show what you need http://www.tytrials.co.uk/trailandtrialsuk/prod_131056--14-19-amp-20-Crankshaft-Oil-Seals-amp-ORing-TY250-Twinshock.html Quote Link to comment Share on other sites More sharing options...
