frenchmike Posted January 13, 2011 Report Share Posted January 13, 2011 please can some one tell the ohms value on my 125 rev 3, at the moment the primary low tension reads 1.5 ohms, and the secondary HT wire is 9.59, is this about right also is there a way to test the stator out put on the bike Quote Link to comment Share on other sites More sharing options...
the_oil_baron Posted January 15, 2011 Report Share Posted January 15, 2011 please can some one tell the ohms value on my 125 rev 3, at the moment the primary low tension reads 1.5 ohms, and the secondary HT wire is 9.59, is this about right also is there a way to test the stator out put on the bike You've not broke it already have you Mike? Otherwise if its not broke don't fix it If you have nip up to my house and use mine while I'm away...The missus will provide tea as well.. Quote Link to comment Share on other sites More sharing options...
frenchmike Posted January 15, 2011 Author Report Share Posted January 15, 2011 Thanks for that, but then we will have too bikes not running, got the bike in pieces as I type this , carb is on my desk, read valves strip and rebuilt at least I'm learing my way around the bike , any one know carb settings, done flot chamber level just the rest I need to know??? Quote Link to comment Share on other sites More sharing options...
