gilly Posted January 13, 2011 Report Share Posted January 13, 2011 don't know if any one has come across this problem before,but on our last event my sons gasgas boy decided to only run on full choke for the whole event we have had the bike from new some two years now and have no trouble at all ,carb is clean,air filter clean,there are no apparent holes in inlet manifold any ideas Quote Link to comment Share on other sites More sharing options...
stork955 Posted January 13, 2011 Report Share Posted January 13, 2011 Gday, its most likely Carb related, blocked pilot circuit is the culprit. The jet and passages are tiny, you need to be careful they are really clean. Compressed air is the best way, and blow from both directions through every hole you can find to make sure its OK. Failing that, check the supply and float needle condition. Good Luck, Cheers, Stork Quote Link to comment Share on other sites More sharing options...
gilly Posted January 13, 2011 Author Report Share Posted January 13, 2011 thanks for a speedy responce it has to be something like that will get on the case as soon as i can cheers stork will post when sorted gilly Quote Link to comment Share on other sites More sharing options...
gilly Posted January 17, 2011 Author Report Share Posted January 17, 2011 stork just to let you know swopped carbs to prove that was the problem and thankfully it was have stripped and cleaned carb right the way through still did not run properly so new one on order cheers gilly Quote Link to comment Share on other sites More sharing options...
