AJP Brakes
beta_trials
Hey guys i have a 96 JT160 GAS GAS 175cc with AJP front brakes. I just fixed a stuck piston problem not too long ago.
(You may remember my post about it. Thanks to all for the help)
Anyway i have working brakes with it but it acts really goofy now. When the bike is anywhere from leaning to the left like in a turn or strait doesn't matter the brake feels like it should. However if i lean the bike to the right only. Either a turn or strait past about 30 or so degrees the lever gets softer or to describe it better the brakes clamp with the lever closer to your fingers. Whats going on?
I'll add a guess on top of ZIPPY'z excelent guess... wheel bearings, maybe a brake pad piston that works "free-er" on one side of the caliper than the other?
good luck.
good luck.
Add to the list: fork flex. If the front end is loose or misaligned, the flex may be enough to not allow the floating disk's ability to self-center in the pads.
Jon
